torque setting for con rod bolts?
  Inferno 182FF
Anyone know the torque setting for the standard con rod bolts? Tried searching on here and no definitive answer.
  Lionel Richie
standard bolts i assume? i "think" its 30nm stage 1 then 68nm stage 2, been a while since i've used stock bolts!
  182/RS2/ Turbo/Mk1
Have you bought new ones? Cause they arent intended to be re-used.
As per Fred I always use uprated ones, seems pointless buying new rubbish ones!
  Inferno 182FF
Was just looking for info if I get new standard bolts. Whats the cheapest can get arp bolts for? So far I've found them on engine dynamics @ £83 delivered? !
Mr R.
  A special one.
Give Roland Alsop a call, they are the cheapest for supertech valves so should be able to beat that price.
Radugns
  Clio 172 ph2
This question again, I've read the manual and says 25Nm + 110deg. Is this right? I know the ARP's torque for this bolts is 57Nm so the standard toque seems to be way higher.
Radu
