tow strap
  • Thread starter Thread starter jacaustin
  • Start date Start date
Have you already drilled the hole out the the right size? I can't remember but I think it's m16.
I went to a motor factors and bought a pack with two bolts that are for bolting a tow ball to a car, cost like 2quid for two with nuts and washer, obv you don't need the nut.
Hope this helps:)
there is a hole already drilled is that not the right size? where you get them from i live in skelmersdale
thanks
It a long time since I did mine, you tried search?
I think the hole is 13mm and needs to be 16mm I think
I got mine from a motor factors, but anywhere with caravan supply's such as go out doors, just take your towing eye with you and try it in the nut before you buy it.
