Ordered mine today be here in two weeks. £2270 plus vat Inc manual winchExactly same position im in!
Need something that's easy to handle and collect new stock with.
Does anyone have experience of trailers that fit in garages? I know there are a couple, one I've seen where you can remove the tower part to reduce the overall length. I would like to buy one also and ideally would want it to fit inside my garage and then put the Clio on the trailer. Garage is not quite a double, a little longer than normal, don't have measurements to hand!
Brian James Minnow will just fit in a normal garage.
They can carry a stripped out Clio, but not sure on their MAM.
Since coming back from the ring, the clio drove fine on AST 5100 setup but I'm thinking in future it might be better to trailer it. My issue is storage and where to keep the trailer when its not in use?
Fantastic thanks I'll check it out and see what it says on the vin sticker. It seemed strange as the Renault documents say 1050kg, yet most similar size, weight, engined Renault's seem to be 1500kg! I'll double check. CheersAs long as the MAM of the van and the MAM of the trailer are 3500kg or less you can yeah.
Most likely you'd need to get the trailer down plated.
To find out your vans towing capacity you can look at the vin sticker in the door shut and subtract the lower weight from the higher weight.
If it does end up being 1050kg I would not go over that tbh, as I believe you can still be done for going over the manufacturer's recommendations.
It's not that it won't physically pull it, but more of the structural strength of the area that the tow bar is bolted to.
Yeah that was why I was curious about the braked weight limit as if it was just a guidance then that's fine but if it's legally enforceable then I'll need to shift the kangoo on for a trafic or somthing similarFrom what I can find online they're mostly 1050kg or 1200kg.
Average decent twin axle trailer will be ~500kg, so it's not going to leave you with much capacity leftover.
If your trying to get round it without doing trailer test then be careful if going for a larger van.
Trafic with a towing capacity of 2000kg will only leave you 1500kg for trailer, car and anything else you would like to carry. Will likely involve getting trailer downplated in order to stay legal and within the 3500kg train weight limit. Most decent sized car trailers will be plated at 1800 - 2500kg gross unless you go really small to the point you can just fit a clio on and no more. Brian James minnow etc
It would be the MAM of the van which you'd need to look at first, which is 3000kg for a Traffic.
That would leave you 500kg...
You'd 100% need a trailer test.
So the one I'm looking at currently is plated up as being 1300kgThey wont weigh you when they pull you but they dont go by actual weight. They go by the plated weight. Even if your trailer is plated for 2100kg and you only have a 1000kg clio on it, your down as 2100kg
I was suggesting 15 inch dynamique wheels (or similar) with a low offset. Plus the removal of spacers, that should see you on the trailer easier.I already have 15" TD1.2 wheels fitted
That was mine that I sold already. The Clio wouldn’t fit so back on the hunt for another trailer againI've just popped up on Facebook if it's any good. It's not mine just see it an thought about this thread
You must have a very light clio if you are expecting to have 1050kg in a clio and trailer combined.Fantastic thanks I'll check it out and see what it says on the vin sticker. It seemed strange as the Renault documents say 1050kg, yet most similar size, weight, engined Renault's seem to be 1500kg! I'll double check. Cheers
I took my car to a weigh bridge aswell got them to print me the certificate and laminated it so if they stop me I van produce it.I wouldn't worry to much if your only slightly over as long as it looks ok and the paperwork adds up you'd be unlucky to get weighed.
I've been stopped a fair few times and never been weighed they just go off the stamps on the trailer/vehicle.
But how much does the trailer weigh as that's part of the MAM?So the one I'm looking at currently is plated up as being 1300kg
I think you have miss read my post....You must have a very light clio if you are expecting to have 1050kg in a clio and trailer combined.
I don't know? It's all very confusing as to what the figures are taken when working out MAM. I simply thought they take the Max figure plated on the trailers plate and then the vehicle weight from the door shut plates and if it's under or over 3.5 indicates if you're breaking the law or not. All I know is the trailer I bought and sold again was 1500 down platesd to 1300 so that the previous owner could tow with his vehicle under the 3.5 mark.But how much does the trailer weigh as that's part of the MAM?
Just found this on eBay.That was mine that I sold already. The Clio wouldn’t fit so back on the hunt for another trailer again
