translating rs tuner fault codes
  182
i have two fault codes my rs tuner is flagging up and im struggling to find out what they are.DF0129 inconsistency between track 1-2 pedal, DF0258 first sensor reference voltage.
could any one shed some lght on this please?
what might cause this fault?
thanks in advance
  182
i have no clue mate, for some reason im not getting hits on google etc. car is a 182FF incase it makes any difference.
ADS_V6
  172 cup clio v6 st
Had this,renault even put new throttle body on.Big white plug by fuses near battery was the cause if i remember corrosion on the pins
ADS_V6
  172 cup clio v6 st
Try search google with the limp mode,mine became scary suddenly no power randomly ,hope you sort it :up:
  182
yeah its a bit strange on the motorway with no power being stuck at 50 ish mph. ill update if i find something or need more ideas lol.
thank you
  172 Cup
I had it the other night df0129 (among others) was from water getting somewhere where it shouldnt have. Went a bit quick through some deep water and put it in safe mode. I checked all the electrical conections under the bonnet and gave them a good spray of wd40. In the morning it had cleared and was back to normal.
koi
Will give it another shot, wasn't sure if there was any clips so didn't want to force it.
