350Z
Hi guys,
I have an 02 172 with 82k on the clock, recently I've noticed a gearbox issue, to explain:
Sometimes when shifting it gets stuck just as I'm about to slot into 3rd, I then have to either wiggle the gear stick slightly or drop down into 4th and then push up.
It seems to happen more on corners, I guess that's just because I've got used to it whilst going straight so I've formulated a pattern in my head to get round it, however I'm not following this pattern whilst cornering!
Every other gear works fine, shifting back into 3rd is also fine, just seems when approaching it from the left that is the problem.
Thanks in advance for any pointers.. As you can undoubtedly see my mechanical knowledge is in the minus figures!!
