Transmission
  172 Ph2. Mmm...
Would a leaking transmission effect power? when i say leaking, i mean it was pouring out at one point after a long journey, plus, whats the most common problem when it comes to a leaking transmission?
  53 Clio's & counting
Leaking transmission? you mean gearbox fella? if you have a leaking gearbox then the box will sieze!
more explanation needed there
  172 Ph2. Mmm...
sorry, gearbox, it was late lol, i found out where its leaking, the end of the gearbox plastic housing is missing a bolt and come away from the gearbox itself, just need to know where the filler plug is and what tranmission fluid is needed for a ph2 172 (2002).
cheers
