tripping out
  laguna coupe
i have got a sound sytem it consist of alpine headunit jbl components jbl coaxial jbl 6*9 two jbl 1200 subs which is running of a mutant 1200 watt monoblock and my 6*9 are running of a 400 watt amp when i turn it right up and some nice bass comes along it trips out just woundered if any body knows why.
is it cause the headunit is getting to hot or the amps felt the amps and they dont feel hot but i can here thr headunit fan on
  Polo + Micra
if your alpine gets too hot you will het something like HI TEMP on the display.
i'm guessing you are getting a high volt drop and the amp is cutting out
more than likely a bad earth
also might want to check out the topic called why have RMS and Peak Power?
  laguna coupe
where is the best place for a earth i currentley have it on the bolt wrer the black plastiic cover isjust behind the back seats
  Polo + Micra
yeah that is a good point just might need adjusting
also have a look at getting a better earth from you chassis to the battery in the engine bay
  Polo + Micra
it might look like a good earth in the boot but might not be( it thought i had a good un but wasn't)
the cable used to connect your batt - to the chassis is really small and can sometimes cause problems
