Trophy running ruff & spluttering on idle
Adz
  Work van
Hi guys needs some help with my trophy ....
It is running ruff & spluttering on idle with an engine management light on constant, sometimes the car will run on 3 cylinders with a flashing engine management light and lack of all power, I have replace the following items;-
Coil pack
HT leads
Spark plugs
Pre cat lambda sensor
I've aleo checked the injectors and they seem ok,
it's also just had a cambelt, depasher pulley, water pump, coolant, oil filter and oil change. The engine is in around 107k, any ideas guys it's driving me mad all I want to do is drive it
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Start with CLIP, run the misfire detection program and see which cylinder has its knickers in a twist first off. Then go from there.
Mick
Adz
  Work van
Mick
What do you mean by the clip? I'll get a diagnostic done and see what's up
  Volvo S40
CLIP is renault's diagnostic software. If you've replaced everything else it's probably going to be an injector even if they look ok. Mine has gone through 2 in 9 months. Similar mileage to you at 104k and no evidence that they'd ever been replaced in the past. You can pick genuine ones up on eBay for ~£21 though so a pretty cheap fix.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Agreed - I've not even seen the car and i'm pretty certain it'll be an injector causing a 10-25% misfire rate.
Just bang x4 brand new units in and be done with it
