TRS Tow Strap
Car  Clio 182 Cup (FF)
I've just ordered one.
Silly question, how does it fit? Is it supplied with a bolt?
Ta
You need an m14 bolt. From what I've read you need to drill through the current tow hole so it can be bolted on the other side
na it dont come with no bolts at all mate. also you have to drill the hole bigger on the strap so you can get the right tho and then just bolt it on...easy job done..................
I'm pretty sure it's an M16 bolt? But no it doesn't.... You have to bore the hole out and cut your grill to fit it in.
Cheers for all the replies...We'll see when the thing turns up. I'll post then. Cheers again
As said..drill out the hole on the strap to the right size so a M16 bolt passes through, cut the opening in the grille so the strap can pass through ok. Bolt screws into the hole then.
You'll need about a 50mm length sized bolt too.
