have to back up what Adamf says.
Standard for standard a Evo2/3 laughes in the face of a gti-r
Tuned tho the GTR is very quick and i am in no way bad mouthing them, there great cars.
Mod wise early evos cheap also.
williams-ant GTi-r time of 12.7 is nice. but seems to of cost alot of money.FMIC takes a big chuck of money.
Early evos do 12.9s with just a 35 quid dawes device and properly setting up.
GTI-R specs:
Power/torque
170kW@6400rpm / 200lb/ft@4800rpm
How heavy
1190 kg
Suspension
Power assisted rack and pinion, 4-wheel independent with front McPherson struts. Rear parallel links with struts
Brakes
Heavy-duty front ventilated disc brakes and rear disc brakes
4-sensor, 2-channel electronic ABS
Wheels/tyres
aluminium 14 x 6JJ, 195/55R14 82V radials
Length/width/height/wheelbase (mm)
3975/1690/1410/2430
Front Track - 1440mm
Rear Track - 1415 mm
Performance (0-100/0-400m)
5.5s/13.9s Max speed - 223kph
Evo3 specs:
Engine
2.0-litre, in line four, dohc,16 valve with intercooled TD05 turbocharger, 13psi, 9.0:1
Power/Torque
mailto:270bhp@6250rpm/309Nm227lb-ft@3000rpm">199kW270bhp@6250rpm/309Nm227lb-ft@3000rpm 7000rpm redline
How heavy
1190kg
Suspension
Independent MacPherson struts with coil springs, stabiliser bar (front), Independent multi-link and coil with toe control and stabiliser bar (rear)
Length/Width/Hieght/Wheelbase
Wheels & Tyres
15x5.5-inch alloys/Bridgestone Potenza RE71 205/50
Brakes
276 x 24mm ventilated discs (front), 260 x 10mm solid discs (rear)
Performace 0-100kph/0-400m
5.1 sec/12.9 sec
I am soooooooo glad I didnt buy anything else now as the Evo is amazing....I havnt even mentioned the seats OMG the seats
Grip in the evo is amazing off the lights.I can basically launch as fast in the wet as I can in the dry
