RichieJA
SCAMMER !!!!
								clio 172
				Fitting the bits for the low boost conversion is real easy it's only bolting bits on. Couple of fiddly bits but nothing hard. I think it could easily be done in a few days if you have all the parts ready to go. I guess the worst part is removing the sump for when you drill the block for the oil return.
I thought it would a lot more difficult than that I suppose I could have the sump drilled at a workshop,
Would the car run on normal map while I drove it to get mapped or would it need towed,
Would low pressure need heat shield installed ?
