turbo service intervals?
stevo172-RWD
  clio 172 rwd
how offten do i need to service my clio172 now its been turbod?how offten do i need to change the oil?air filter? also plugs cause they work harder now?also im a bit worryed about summer heat! will it kill the engine?
stevo172-RWD
  clio 172 rwd
just trying to get sum idea thats all.turbos in general.otherwise i might fuk it up somehow wen i get it back at long last!
I'd be buying oil and filters in bulk if I were you and change oil and filters and clean the IK or whatever its running ever 5k maximum and more likly 3k. If you track it them I'd chnage the oil straight away I'd imagine engine temps will be quite high.
There not many turbo Clios out Nic Read has a high pressure turbo valver engine with 240hp or so but apart from that any Tony (who never started his engine I don't think) there are few owners.
leave it to idle for 30sec-1minute before turning it off, this is everytime otherwise you'll feck the turbo. and same mwith starting it up, let the oil get around it before moving so 30sec idling.
stevo172-RWD
  clio 172 rwd
yh im used to warming her up cause it sometimes takes 30mins to get out of my works car park.every other d*ck just races away as soon as the engine starts!
1
16vturbolee
i have no need as i run a charge cooler:eek:
  TDI tyre shreader
Aswell as the 1 min idle drive it easily for the last bit of your journey keeping off boost low rpm etc to let coolant and oil temps to lower.
