Is there any easy way to do this without converting to cable throttle? Failing that, would switching to cable throttle be easy enough (Ph1 throttle body and pedal)?
I'd like to be able to turn off the TC (power reduction) while keeping the ESP because I find it works quite well and actually benefits handling at the limit in many scenarios.
It would be as simple as ignoring DBW commands other than those from the accelerator pedal, but that's probably easier said than done as it's probably all ECU controlled.
Sorry if this is in the wrong section but I figured an engine person would know if anyone did.
