Tyre Pressures.
RDH
Could someone post the tyre pressures for a 1.2 please.
I've lost my manual so need to know tyre pressures as mine look as though they aren't at the right pressure.
Thanks alot.
should have less pressure in the rear as there is no weight there so you dont need as high a pressure. tyres will last longer if you run 32 front and 30 rear!
Iirc its 2.0 bar rear and 2.2 bar fronts cant tell u in PSI!!
