Tyres, offset, profile, HELP :(
Hello
Can someone give me a quick beginners guide to tyre sizes, offset's etc as im abit confused
I want to swap out the alloys on mine for something else but before i start chucking money into it i want to make sure i fully understand what to buy & what tyres to get. Also if i would need wheel spacers (i think that has something to do with offset?)
Any help would be appreciated, just wanna buy right, buy once :p
Http://www.willtheyfit.com will show you if your new alloy and tyre combo will fit, or rather how it will fit relative to your existing set up.
Have a simple google for understanding tyre markings and alloy offsets.
For tyres:
195/50/15R V/H/T is my tyres.
195 = Tyre width in mm
50 = aspect ration, it's the % of the width for height. lowe rthis is, lower the profile
15R is the size, i.e 15".
V/H/T etc = The tyre load/speed rating. Some tyres are rated for higher speeds than others.
For Alloys:
My alloys are ET37 7J 4x100 60.1
ET37 = This is the offset from the hub. the lower the offset, the more it will poke out i believe. This is in mm. Spacers effect this, so et37+15 mm spacer = ET22.
7J = This is the Alloy width. I've not seen any letter except J but the 7 refers to 7 inches wide i think.
4x100 = Bolt hole spacing. 4 holes, must be 100 the fit on your clio.
60.1 = Alloy centre bore. Must be 60.1 to fit snugly. If it's smaller than this, you'll need it machined/bored out. If it's bigger, maybe you can get a spigot or sleeve to reduce it.
Hopefully that helps somewhat.
Just a slight change to the bit above. The 'R' isn't part of the wheel size. 'R' stands for Radial Ply and is the construction type of the tyre. This can also be a 'C' for commercial tyres.
Radial tyres will be the only tyres you can get for it. Was just pointing it out in case you came across a commercial tyre.
usually have their offsets and width stamped on the inside of the alloy. if you search on the forum - i'm sure you can find the standard offset etc.
Had a little look, i believe that standard dynamique alloys are ET43.
