tyres what would happen if
Car  clio sport rs 200
got conti sport 3 215 45 17 standard tyre what would happen if keep same alloy but put 225 45 17 or can you even do that help please people
it might just overlap more that's all. fitting would have no problems mate. You have to question if there is any point in doing it though.
If the 215 45 is your standard tyre on the alloy the 225/45s will fit.
Its only 10mm wider.
I got my tyres cheaper with the 195/50 size.
Well with 15" wheels, I've had 6.5j and 7j. Both take 195's, but only the 7j's take 205's. I'm not saying they won't fit, merely that it's worth checking 1st. I wouldn't put 215's on my 16's for instance.
well believe it or not its cheaper for me to get micheal tyres wider than is same size by 20 quid a corner only 100 each and contis are 90 so dunno what to do
Need to know the width of your wheel TBH, ITs alright people saying oh they'l fit as ive had them on my 1*2 etc but your 200 rims may have the biggest tyre on that they will accomodate safely, You could have a wider tyre fitted and the handling go all sloppy due to flex
well deffo dont want that so how do i get that will it be in the hand book or what or do i need to take tyre off get size
If you're a member of Costco's see what price they want, they are good for Michelin tyres.
I'm running 225/45r17 on 7.5" wide rims on the wife's Mazda 6- they will easily fit on that rim width.
i had 7j rims and was told 205s were standard, so 225 on 7.5j will work fine,
im now running 165/50/15 on 7j wheel :D
