Can't up-date Windows Defender,Spyware Doctor,PC-cillin etc.
the sys
What do l have to do? I have run AdAware and also removed the serv.sys crap using PREVX CSI.
could be entries in your hosts file that shouldnt be there. start > run then copy and paste/type the following
Code:
notepad %WINDIR%\system32\drivers\etc\hosts
should load a notepad window showing some text, there should usually only be a description of what the file is, then usually just one entry for 127.0.0.1 localhost.
# Copyright (c) 1993-2006 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
