Underseat Wiring
  Clio 172
Hi all, as some of you know I have just removed my PH1 front seats (single handedly and with alot of under car swearing) and I am now left with some wires and I'm guessing pretensioners inside the sills next to the seats. Can I remove all the wiring and pretensioners with no issues and if so where does the wiring link to the loom so I can unclip it rather than cut it out?
Thanks Andy
len_beach
  E92 M3,172 track car
Does removing this wiring bring on th airbag light if you've disabled the pretensioners with an RSTuner?
it connects under the seat (grey and black connector on a ph2) a 3.3ohm resistor is needed to keep the airbag light out. check the guides section for more info.
Black things on the sills? If its what I think you're talking about its just the lower mounting point for the seatbelt, Its just a weird shape bit of metal tube. Unscrew the torx bolt and it just comes out and the belt slides off it.
  Clio 172
I hope its not raining Thursday as I need to get the seats in and get the rest of the gubbins sorted out in the interior.
Still need to know where I unclip the wiring in ther floor from the dash loom.
