uprated cams
  ibiza cupra
just wondering who has had this done and wether you thought it was worth the money. its somthing im going to be looking into soon but im not sure wether the money its going to cost would be worth the amount of gain i would get from it.
i also understand that there are a few options like piper regrids and catcams as well as others but i dont know what to go for as i have heard good and bad about them all.
also, what sort of gains do you get from cams and how much would i be looking at spending for the cams, fitting, mapping ans any other bits that i may need?
cheers all.
Minefield.
If you are sticking with standard management you need to budget for at least £1700.00 upwards all in for a good quality set, fitted, mapped etc (it's effectively a full cambelt service + the cams themselves + proper mapping).
There are some questionable quality regrind type cams floating about that you can save some cash on. Don't expect more than 155ft/lbs 185bhp.
  ibiza cupra
£1700 i thought id be looking more at £1200 at the most :eek:. maybe thats a no then as for not much more i could get itb`s.
think meybee ill get some coil overs and maybe a carbon bonnet instead lol.
  53 Clio's & counting
Brakes and suspension mate, will make soooo much more a difference than anything engine wise.
Though cams are good, id wait until your due a cambelt change to do them if you are going that way.
Id go itb's but im biased lol (to be fair iv always wanted itbs)
  ITB'd MK1
Doing testing ASAP on this. Want to get cat 421s working as well as possible on standard ecu. Better with standalone though, as said already.
Don't bother with 428s. Not found a setup they really compliment at all yet.
  Lionel Richie
^i disagree, i've done 190+bhp several times using the oe inlet (albeit matched) and so far 212bhp IIRC on bodies, for a "mild" cam they do well!
my new ones are going for mapping next week hopefully, fingers crossed it does 200berries!
Runs and idles bloody well too!
  RB 182
Hmmm... well you know i'm half and half about ITB's or the JMS setup, give me a shout when you have the figures and costs as this might be another one to consider :D
Are these very wild cams or ok for daily use?
  Lionel Richie
i'll take you out in the car when its done ;)
i did more torque and 9bhp less when compared to a stock 172 on ITB's (same rollers) on stock matched inlets with 428 cams ;)
  RS RIP
it's possible.
171,6 at the WHEELS , throw an equation of 15% transmission-loss on there and you'll get a very healthy power. More likely is 12% loss though
Greeny.
  440i + 182
More like 2.5k for a decent ITB kit fitted by a decent company, unless u can do it all yourself of course.
  Ph1
Do some research on the different cams the different profiles, what they give you low down, mid range etc and match them up to what your wanting from your car.
You might get some cams that give you a good paper result for the boys down the pub but if youve got 1.1's beating you till you come on cam the car will probably feel less driveable. All depends what you want.
The problem is Andy that there are very few people out there that will actually do the research, and even less that actually understand how a cam profile & it's numbers relate to changes in the cars performance.
  ibiza cupra
well it doent look like im going to get much more out of it with out spending silly money so i think i may go for some coilies and a remap instead.
not sure wether to go for an rs tuner or go and get it done properly. both would cost about the same to me as i would need to buy a laptop too if i were to get an rs tuner but i know i would get a bit more out of a proper map.
what do you recon? is it worth a proper map with just a panel filter, decat and strait through system or would there be nothing in it?
  Ph1
Dont right cams off altogether. My old pretty mild spec Piper regrinds matched with a few other mods left a RS Focus and a R32 Golf standing on a quater mile the latter of which had repeated runs against me with the same outcome
  ITB'd MK1
That's what I most dislike about 428s. All the gains are right up the revs. They can work but you need to wring the Hell out of the engine. 421s are man cams
  BMW E36 328i Sport
If you do track days cams will be a good mod as you will be sitting at high revs all the time it just means on road you have to rev the t*ts off it to get it flying. I can't speek for experience n a Clio but I had a cammed saxo and on road my friends ctr would pull away from me and lookd like a faster car but flat out o-100mph they were equal.
  Renaultsport Clio 172
I have E&D cams and they do give more grunt from 2k all the way to the cut-off. Just don't get cought below there as you will be left behind, but may catch up later, just get above 2.2k, mine is faster that most 172's by a noticeable margin. Car is more agressive and the and midrange is also more solid, and that is with my cat left in place. Past 4K, oh!!! it shifts!!!!
I would go for 421's, C&B, Shricks or E&D. All these have similar specs overall.
  RenaultSport 172
As above in reality I think from 428s your looking at around 180-190bhp Some lucky ones get just over I believe, I got 183bhp but the way the car drives now is fantastic so much quicker through the midrange all the way to the redline!
  RS RIP
lol i was just Google-ing to find out how wheelpower measures up to flywheelpower and found this link; it's good for pub-talk haha, made me happy anyway..
http://www.pumaracing.co.uk/coastdwn.htm
it seems mine is making 201,7 with the above mentioned C&B cams, matched inlets, exhaust manifold+decat + modified airintake (made 171,6 wheelpower, Fastchip RR result)
So, if your engine is a good 'un , nice and loose, high power is possible with cams and mods to match these
  Ph1
If 428's are mild and 421's are more lary then surely the 421's would have a bigger trade off gain vs loss ?
Im hoping to get these new 428's mapped shortly but it currently pulls in 4th from 1500 rpm right up to 60+ without any bogging down
  Evo 5 RS
428s are a massive waste of cash man, like Danny said it takes a fair chunk down low and gives you a smidge back up right by the limiter. If I had my time again 421s are the way forward.
  Ph1
Out of interest, is yours flat till about 4.5k then when it comes on cam kicks in with the power?
