urgent help needed ktec coilovers
im fitting a set of ktec coilovers to my 172 cup but there are no instructions how are the fronts held in place at the top?i have taken the top rubber mount off the old damper but do i then need to take the other rubber seat off the old damper using spring clamps as i was told i wouldnt need them?
  Mondeo TDCI 130
yes! you need the top mount for the coilies.
Don't need spring clamps, undo it slowly!! Get a mate to put a bit of pressure on it, will make sense!!
They won't fly apart, don't worry! :) Done loads!
DrR
  VW Golf GTD
Assume there simular to my Vmaxx ones, just wack the bearing and rubber top mount on top the new k-tec ones.
Yeah no spring compressor needed.
