urgent help needed please
  renault clio 172 2002
how the hell do you get the amp wire the posative from the battery to the boot (through the bulk head to be more precise ) i cant seam to find any way through the bulk head as it is insulated both sides and there are no other wires running through apart from what looks like the bonnet catch cable all help is appreciated
  Clio MK2 (1.2)
u need to wire it through the wing, is tricky especially if u got 1 ov the big amp 1's, and itl come out were the passenge door is, then just put it under the seal .
  172
no you dont,use the bonnet release grommet,cut a hole out of the grommet pass the cable through then seal it up with some silicone sealant
  No wheels :(
NOOOOOOOOOOOOOOOOOOO!!
Just push the gromit out with a screw driver and push through the wire, i have and its the easiest way, took 2 secs!!!
Wanna pic tmoz when its light?? Pm me :p
Cheers, Sam
