URGENT HELP
  3 Series touring
Hi, curently walking home and using phone internet!
Started the 1.2 and it idled at 1500rpm! And theres no response when i press the throttle!
What could it be?
Ben
  182 Cup
No idea. Open the bonnet and check - if it's fly by wire then it could be the unit on the throttle body or the sender at the pedal.
Rob
Shoulda asked me for a lift mate! Unfortunately i have no real mechanical knowledge so cannot help. But if you're around sidcup then i have some tools etc.
  3 Series touring
cheers! its only a half hour walk though!
the electrical warning light was on when i started the car....
plugged in the trouble code reader when i got back up there and voila..runs perfect, only problem is ...no trouble code :S
im confusedd!!
  Clio 182
hi mate i am a tech for renault, u will usualy find with these that the throttle body gets dirty and greasy needing a good clean out and reinitializing by your local renault dealer OR pedal potentiometers also play up, what did the fault say on diagnostic machine?
  3 Series touring
the fault code reader says no codes...its done this quite a lot recently, the electrical warning light comes on (car still drives fine) then when i start the engine with code reader in (because i was told not to plug in while ignition is on) the fault is gone and not recorded :s
