URGENT HELP !!!
MarcB
Car  Vw Golf
Tonight for the first time ever my car has decided to start playing funny buggers.
When out to get something from the car and opened it perfectly with the key fob.
Then locked the car with the key fob and everything was fine.
About 10mins later the alarm just made a long non stopping beep.
I opened the car with the key fob and and then locked it again and then it was fine . . . . . .For around 40mins.
The Alarm keeps going off all the time now.
When i lock the car the Door Lock Light on the hazard pannel is on and the dash light flashes as normal.
The light on the hazard pannel then fades / dies and then goes off and then the alarm goes off.
All the doors are shut and the boot and bonnet are closed also.
The car is covered in ice as its currently -3 on the car and its solid shut. . . . could this be a problem ?
Is there a way for you to reset the alarm and if so how ?
Sat for ages working it out and then decided to go for a long drive and de-frost the car and see if there was any difference with it.
After spending 35mins in the car i worked it that it has only happened since i opened the boot.
10mins later on a small dark country road i ripped the rear boot plastics off and had a look at teh lock to find this.
