Urgent.. Interior Question..
On the door panels on clio mk2s... theres the material part of the panel... which is usually the pattern on the seats etc... Is this panel on the door seperate?.. can it be removed? If so does any1 know if you can buy the material panels seperate from renault? Quick as possible please..
  clio 172 flame red
no the material does not come off it is glued on tightly and not comming off you are better off finding simular metail then glueing over the top of this and tucking around the edges with a knife i did this with mine i bought 172 interior and needed the doors the same so i just glued over the top using copydex glue from b&q comes out perfect to.
