Quote: Originally posted by Liam182 on 10 August 2004
abs only works when braking and same goes for TC when on the fast pedal.
if on a bend and fear losing it should you
a) carry on hoping TC will sort it or
b) slam on and use abs?
does this change in wet/dry etc?
if a wheel spins the tc applies the brake to the spinning wheel to stop it spinning and so power is also transferred via the diff to the wheel which has grip. the tc system uses the conventional abs block but uses some additional solenoids/valves to direct fluid from the pump and to the wheel it wants to apply the brake to. when a wheel spins the pump is operated to create fluid pressure and the solenoids/valves direct the brake fluid (under pressure) to the wheel (slipping/spinning wheel) that the brake needs applying to.Quote: Originally posted by Liam182 on 10 August 2004
didnt realise the traction control used brakes, thought it just reduced engine power to individual wheels
the esp only works one wheel at a time and adjusts engine torque. below is two examples of understeer and oversteer both going around a right hand bend.Quote: Originally posted by Yugguy on 11 August 2004
No way would I slam on, I would (and did, the other week) steer through the corner and let the esp brake each wheel as necessary.
