V6 Speed Sensor/Conecting Sat Nav
right ive installed my sat nav system, a pioneer X1R. And all i need to conect is the speed sensor, can anyone tell me where it is?
Best idea would be to use the speed sensor fom the normal steroe wiring loom which goes to the back of the stereo.
The speed sensor wire is the track one on the black connector block on the stereo.
Its the violet one
The yellow one is the fuse one
The connectors are labeled though have a look at the photo you've posted you can see the number on the sie of the connector block.
one three five seven
Clip bit here two four six eight
This is a basic idea of your wiring you've got in your picture the number indicate the block and block 2 is the one with no wire in it and the one with the thick black wire is in eight and the yellow and purple wire is in connector block seven.
