Are the Valeo coil pack connector std connectors you can buy off the shelf? I want to make an extension lead to give the loom some more length to relocat the coil to where i want it. Dont really want to cut the loo to do it.
Simtek, mcal, Polevolt, vehicle wiring products are the places I'd be looking at but its an odd one so may not be listed. I'd give Neil at Polevolt a call as I'm sure he would be able to get hold of them. I've seen one before so they are definitely available just depends what manufacturer makes them.
What size wiring is used for wiring the coil pack guess 1 power ans 2 triggers. Does the power wire need to be a bit beefier to supply etc? Have some 16amp 1mm copper core rated wire not sure if its enough.
