valver cold air feed!
  20VT Clio & 9-5 HOT
iv got a bmc cda, and only just fitted it correctly (well sort of) just waiting for some proper ducting from DT!
anyway, iv took a foggie out to get a cold air feed goin into it! but the ducting im using is 70mm and the standard hole is about 2cm round! lol can this bracket be taken off or shall i just cut it wider?
any ther ideas welcomed!
Cheers!
coolspot007007
  Seat Leon Cupra
where the oe air feed goes into the bay through a metal plate? If so thatll only take 50 or 60mm (cant remeber which) at a push so yes that will need cutting and the splash guard too.
  20VT Clio & 9-5 HOT
yeah thats the one mate...im sure u sent me some pics ages ago of yours? if u got any can u email em to mailto:craiga@freeuk.com">craiga@freeuk.com
cheers
craig
coolspot007007
  Seat Leon Cupra
no pics im afraid, mine is cut for 100mm :) so 70mm shouldnt be too difficult., that metal plate is tough though, drill a load of holes around the circumference to widen it and saw the excess out neatly, with 100 a lot of the splash guard needed to be cut back, but thats just trial and error to get the fit.
coolspot007007
  Seat Leon Cupra
i wasnt actually too sure whether the plate could be removed by the way, but it seemed as though it could be important to the structure in a crash so i bolted some 5mm steel plate around the hole to give it some strength back, just in case.
