valver gear box
a new one from renault id circa £400 +vat iirc second hand ones vary depending who you know and what condition they are in!
realli?? is that fitted at renault? qutie cheap if it iz, if not how much loookin at 4 fittin? thanx
Fitting will be quite a bit I think.
I thought they were about £400/£450+VAT from Renault (supply only), exchange item - so you give them your old one.
Thats supply only and its an exchange as Daz said. Fitment depends who you go to your looking at about £250 to £400 with a new clutch (might as well change it IMO)
well im not 100% sure its my gear box but from people tellin me i fink it iz, wen im flat out in second or 3rd sumtiems jus stops pulling 4 a second? n wen i turn left small noise cummin from my left wheel, thers knockin aswell but i fink thats jus engine mount or exhaust.
I was quoted £550 and £600 by two Renault specialists for the Clutch alone!
lol Renault and nissan do lick balls at labour costs summot like £60+vat an hour!, i definatly cant afford a new 1 guna hav to try get a recondition 1 from the renault breakers or sumthin
Yep they charge a funtune labour rate and its listed as a 6hr hjob chnagiung the whole gearbox doesn't take any more time though than just a clutch.
Shop around and you'll find some places will do it for £300.
Check for sure that firstly the noise isn't just a wheel bearing. It should be noise when turning one direction, and the quieten off when turning the other.
As for the loss of power in 3&4, dunno. If it was transmission, I would expect a (fairly loud) noise to co-inside loss of performance. Are you sure you just don't notice it in 1&2, and never reach that rev in 5?....
Just a thought
its not wheel bearing noise had those both done, my m8 seems to fink the gear box is ok n that the flatspots are my clutch slipping?
