Valver springs n shocks
mostly need the shocks as my front left has gone.
to the point, Would shocks of a valver fit my mark 1 phase 3??
its a 1.2?
would they be suitable???
wheres the cheapest place for shocks?????
thankksss
I don't think they fit best idea is to check the hib spacing is the same bit even if they fit there not ideal for the car.
GSF for cheap shocks etc.
Could be worth giving it a go, would make the setup alot stiffer but still have a normal ride height.
On my 1.2 ph3 the hub spacing was 54mm and iirc valver shocks are 54mm.
Gsf would be the cheapest for shocks or Unipart etc.
anyone know the part number for front mk1 shocks on GSF?? i cant seem to find them by searching:S thanks for the help
bit of a noob question, whats stud spacing?? wher can i find out mine?? or is it 54 mm on all phase3s?
GSF:
R45530SHOCK STRUT BQ FR CLIO 1.2/1.4/1.7/1.8 8V/19D 54mm stud space
is this the correct shock absorber. i havent a clue
GSF:
Sounds like it you need to measure this distance on your hubs but they are likly to be 52 or 54mm. You measure between the center of both bolts.
