Hi Im Martin from Denmark, sorry my bad english
have eny of you experied this?
I have just damaged with my Clio engine, which have going well for 2 years. but the other day it was on the dyno and we raised the rev limiter from 7200 to 7500, not much I think but after some normal driving without problems sudentlig at hi rpm the engine stoped with bad noises. it seem that the valves is floating at hi rpm and they dont get closed quick enough before the piston goes in top, so I damaged the head, valves, pistons and the cylinder block.
The timing belt timing was ok and I have fixed the belt gears with a not. so this is not the problem.
but only 300 rpm more than standard?? is this enough to make the walves floating.??
Have enyone tried to use harder springs or dubbel springs then the one catcams sell?? Maybe if they are too hard to press the hydraulik lifters can not do it?
Have someone tried to build the hyd lifters to mechanical??
ore have another sugestion.
If this helps Engine data:
fixed crank puller
Catcams 292/284
Catcams valves springs
fixed Catcams adjust. camgears
Catcams conrods
Renault Sport forged pistons
4 endividual throthle bodies
homemade 4-2-1 exhaust manifold.
225 hp at 7258 rpm
240 nm at 5516 rpm
fixed crank puller
Catcams 292/284
Catcams conrods
225 hp at 7258 rpm
240 nm at 5516 rpm
