VBA Help? (Probably easy)
mace¬
  Clio
OK I know nothing about VB, but I've been tasked with tidying up the reporting and changing a few things, In access they clicked a button ran some reports and emailed them off, unfortunately they get about 23 emails one after another so I decided to put them all into a folder on the network.
Now my problem is, if I just run it from a Macro it works fine, once I then try and put it to work from the button it does nothing other than prompt from the drive letter and dates. When it comes to execute the queries is does nothing.
Anyone tell me why?
So the button does this...
Code:
Private Sub Command108_Click()
    RunMonthlyStats
End Sub
Then this
Code:
Option Compare Database
Dim InputStartDate As String
Dim InputEndDate As String
Option Explicit
Public Function Output_Test()
    Dim message, title, defaultValue As String
    Dim myValue As String
    Dim Drive, My As String
    Dim fso As FileSystemObject
    message = "Enter the drive letter that is mapped to E-HEALTHCARESUPPORT"
    title = "Monthly Report Output Location"
    defaultValue = "S"
    myValue = InputBox(message, title, defaultValue)
    InputStartDate = InputBox("Please enter Start Date:", "Start Date")
    InputEndDate = InputBox("Please enter End Date:", "End Date")
    If myValue = "" Then myValue = defaultValue
    'Drive = "\\tsclient\" + myValue + "\05_Proj_Mgmt_Results_and_Rpts\Msmt_Data\Monthly_USD_Reporting"
    Drive = "\\fileshares.corp.hp.com\groups\e-healthcaresupport\" + myValue
    On Error Resume Next
    If Dir(Drive, vbDirectory) = "" Then
        MsgBox ("Directory does not exist: " & vbNewLine & vbNewLine & Drive)
        Exit Function
    End If
    DoCmd.OutputTo acOutputQuery, "zzPM_Output_Test", acFormatXLS, Drive + "\Test_Output.xls", False
    DoCmd.OutputTo acOutputQuery, "zzPM_Output_Test1", acFormatXLS, Drive + "\Test_Output1.xls", False
End Function
Public Function StartDate() As String
    StartDate = InputStartDate
End Function
Public Function EndDate() As String
    EndDate = InputEndDate
End Function
Thanks, I can't figure out whats changed.
mace¬
  Clio
No worries panic over, ambiguous name, forgot that I had left my original one I wrote as a test there.
So StartDate and EndDate were duplicated. i was wrong as well, once I'd duplicated them they both stopped working.
