very upset
  clio sport 172, 2002
just been to my local garage, coz i have a little oil leak, and they said it could be cuming from the rear main (the seal behind the flywheel) and that these go on clios alot!
has anyone ever had this problem??
and was it easy to solve???
thanks steve
  clio sport 182
i had it mate,my engine blew first off i got it back from renault as it was under warrenty and the final drive out put seal ie the one your talking about had gone,i gave it renault back and they fixed it,its a gearbox out jobby mate
yeah i no its going to be a gear box out jobie, does any one no on how much of a big job its going to be
  Monaco RS Clio 172
give rentec a call my friend.. see what they can do for you. they are in portsmouth if that helps.
Martin_172
gearbox out and back in is a good what 3 hour job anyway? atleast, be as well changing clutch while your at it then you have the price of gearbox oil on top of that too
just been to the local garage, and its booked in for wensday, the crank seal is £16 and the labour will cum up to about £140ish
the lad that had it befor me had the clutch dun at 50,000 its now on 58,000 so not sure weather to do the clutch????
does this sound reasonable????
Christopher
  Z4M
That's a good price!
Check the clutch isn't covered in oil when you're there.
  ITB'd MK1
sounds too cheap, gearbox off is not a simple job on a clio due to how the subframe is right beneath it, so it's either engine out or subframe off before you can even see to get the box off.
  M2 Competition
Most clio's ive been under have a tiny amount of oil that leaks out, catches in the under tray. Pretty normal.
You dont mean this do you?
