vibrating noise (Contains video)
Paul.M
Hi guys
Well my car (04 182 with 102k) has started making a vibrating noise as heard in the video below..
My first thought was something driveshaft/ wheel bearing related however I've had it jacked up and there appears to be no noise as such spinning the wheels in the air (I have another video of this if anyone thinks it will help to see).
After I did this it I then started thinking possibly clutch related as it seems as if it may be happening just after the cluth is on its bite point?
To be honest though I am lost with it and could do with a bit of help, it is booked in to my usual garage thursday morning but I thought I may as well ask and give us somewhere to start.
Thanks in advance :)
Sounds quite 'tinny' are you sure it's not the exhaust rattling on something when the engines under load?
might be exhaust manifold, when its cooled, use your knuckle or a spanner to knock each of the 4 manifold tubes behind the engine.
