Coops Mk1
Lots of Scrap...
copied post from other forums, any input greatly appreciated as am about ready to bin the whole damn car....
Right am about to go for my 4th drivers side driveshaft tomorrow
my question is, why does it keep vibrating?
the story goes, i lowered the car after the engine rebuild and changed my driveshafts both sides at the same time (cv boots knackered, so figured better safe than sorry and go for re-furbs from renault) and there was a massive vibration through the car on left turns. i changed wheel bearing that side, no difference, so eventually it was pinned down to shaft
shaft was changed again, was fine i think for ages, but now having fitted my r888 and really pushing it round corners, the vibration is back again, this time its whilst pushing a lot harder, and tight corners only pretty much but its there and its bad when it happens.
now i talked to my dads mechanic this weekend and he thinks it may be because the car is too low, so when the suspension compresses aswell as hubs already being higher than diff, the shafts outer cv joint is at too much of an angle and vibrates. is this possible? how come it hasnt happened to anyone else? mines low but there are lower cars out there so what do you guys think?
also why only this side, i mean i realise that the engine and me are on that side so its got more weight to push down, but still, cornering the other way at any speed is fine, no matter how hard i push, its only left turns where it struggles
i'm really hoping its just another dodgy shaft, but any advice/experience on this would be much appreciated!
sorry for the ramble
cheers
Ben
free bump
still bloody doing it, new shaft, so its not the shaft itself, or maybe it is but its because the shaft geometry is out?
noticed today that looking top down through the engine bay the hubs are behind the output shafts of the gearbox, so the shafts are naturally swept backwards, is that right?
also if i undo the hub nut, should i then be able to move the shaft in and out of the cv joints/hub spline both ways?as in slack enough to extend and shorten the length of the shaft? and should this be possible with weight on the wheels, or only when jacked up?
cheers
Ben
arb fouls wishbones, but does that on both sides, and did it on my old valver aswell when it was this low, spose cud be that, am raising it this week to see
could it be diff bearings in the box? i wud of thought if it was there wud be more symptoms, like cornering both ways etc?
rollpin is new :wink:
cheers
Ben
free bump
cheers
Ben
