Vibration through clutch pedal
Car  RenaultSport clio 182
Hi i have an 04 reg 182, recently there is a lot of vibration coming through the gear lever and clutch pedal when accelerating, the clutch pedal also seems to move slightly under acceleration, could this be a mounting problem, if so what should i be looking at? thanks
Hi thanks for your replys, iv looked at the rh engine mount and it appears to have moved, you can see circles where the washer positions used to be, im going to remove battery and have a look at rh engine mount, what sort of job is it to change these mounts also the gearbox dogbone mount. ta
