Clio 182
Hey all,
I have done a search and at first I thought it was one of the engine mounts, but after listening again with someone in the car revving it, it certainly sounds as if the noise is coming from the inlet manifoldy area :S
Another thing that makes me believe it's not mount related is, give the car the beans and noise goes away, with mounts the noise gets worse doesn't it? Stick to/or around 3k on partial or lift off throttle and the tinny/rattly/vibrationy noise comes back, hmm, can anyone helps??
Below are a couple of vids I took, sorry for the naff quality, taken on phone...
Any helps mucho thanks, I'll take a look again tomorrow and if needs be, will take the upper manifold off and re-tighten it! If that fails, meh :S
Cheers, Graham
Cheers, Graham
