Viewing a 182 tomorow
Following on from my last thread i am going to havea peek at a car tomorow. My friend who is a mechanic is coming along to check the car is sound but is there anything i/he should pay close attention to on a 54 plate 182?
Any help would be great.
DrR
  VW Golf GTD
there is a masive guide in the guides section i believe
  Renault Clio RS 182
i have a 54 reg 182, i just checked for obvious signs or wear on the car, asked for reciepts from services, tires, mot' and what have you.
the only prob i had with mine was the oxygen sensor, it didnt work properly so needed replacing.
CrippsCorner
  A250 EbAMG
Same here, seems to happen to all of them.
I'd personally only look at a car that had the following....
4 good quality matching (at least Axel matching) tyres,
FSH, including a cam/aux belt within the last 20k.
Standard suspension set up.
Brakes have plenty of meat on them.
All that work alone will cost £1000 should you buy one that needs it.
If all those are ok, then chances are its been well looked after and will serve you well.
