VW Golf Wheels?
  RS Meg 175
Will VW Golf/Corrado fitment wheels fit the Clio at all?
They are 15x7 and 4x100 stud fitment.?
Guys
  1.6 focus zetec....
all the info you've given us is spot on but we need the offset...if its 35 - 45 then your alrite...
  1.6 focus zetec....
By having a quick search on google it looks as though they have roughly the same offset as the clio... wouldnt like to say for sure though mate!!
Kiza
  1.6 focus zetec....
35-45....can use a spacer on et45 which if you use a 5mm spacer will make it et40 ...you get the idea lol
  RS Meg 175
Okk i gets you :)
so the higher the offset the further in the wheel sits?
and clios can only take 35 - 45 :D
  1.6 focus zetec....
Lol thanks chap!! Im quite getting into the euro scene so seeing a few pics would be nice bud!!
Kiza
  RenaultSport clio 172 mk2
Guys
The PCD needs to be right. That is.
The offset needs to be right. As you've been told that can be corrected by a spacer. Depending on the direction.
But you still won't be able to fit if the centre hole is too small. And if the centre hole is too large you must get a spigot ring to match. You can't just locate the wheel with the wheel bolts.
