want to upgrade my desk top, zero idea!
Car  transit van, ph2 172
right my pc is running very slow and i want to upgrade it either a desk or lap top up to £400 mark,
my pc was made by a mate for me but i dont have a clue what it is, to upgrade it from,
on screen it tells me intell pent 3 732mhz 384mb of ram
ive opend it up and from what i can read it says
dimm slot1 128mb,133mhz
dimm slot2 133x64c3/256
dimm slot3 empty
agp/aimm slot 4mb aimm 133mhz
i only use it for surfing net but would like to sort few games and downloads etc,
ive been looking at all the web sites to upgrage but cant figure out what all the mhz, gb ram etc relate to,
any help would be great
ill try that now but im not very good on pc, i know what i need to and thats it, lol,
would like to do more like downloading games, etc
hope it makes sence to you mate just load of rubbish to me, ??
Property Value
Memory Summary
Location System board or motherboard
Maximum Capacity 512 MBytes
Memory Slots 3
Error Correction None
Use System memory
Maximum Capacity 512 KBytes
Memory Slots 1
Use Flash memory
Device Locator XMM1
Manufacturer Micron Technology
Part Number 8LSDT1664AG-133B1
Serial Number 31461051
Capacity 128 MBytes
Memory Type Synchronous SDRAM
Speed 133 MHz
Data Width 64 bits
Form Factor DIMM
Total Width 64 bits
Device Locator XMM2
Manufacturer Nchip
Part Number 32MX64PC133CL3168
Serial Number 04BC181A
Capacity 256 MBytes
Speed 133 MHz
Data Width 64 bits
Form Factor DIMM
Total Width 64 bits
Device Locator XU15
Capacity 512 KBytes
Memory Type Non-volatile FLASH
Data Width 4 bits
Form Factor Chip
Total Width 4 bits
Warning! Accuracy of DMI data cannot be guaranteed
that one has sold out, dam it,
i would say 90% net and word etc
bit of gaming
storeing pics and music etc
im thinking desk top more, are they better vaule for money over lap tops ?
generally pcs are cheaper than laptops, £:Performance
you need a monitor too or just a base unit?
you can build a decent spec base unit for £400 that will play most old games on max settings and new games on mediumish
try overclockers.co.uk or novatech
just the base unit i have i okish screen at the mo, that sounds good to me ill check the link out now thanks mate
how does my,n compare ?
Processor
AMD Athlon X2 4200 Dual Core 64 Bit Processor Processor Speed2.2GHz Memory2GB DDR2 667MHz Dual Channel Memory Hard Drive250GB Serial ATA II Hard Drive
well yours is a 700mhz processor, that is a 2200, so it should in theory be 3x quicker.
it has 4x as much ram as yours
what graphics cards with it?
cant find that one again
if anyone finds a good deal post the link for me i give up dont know what im doing lol,
Plus its a dual core processor so its essentialy light years ahead of what you have.
Basically if you don't play games, thats absolutely fine. If you want to play games the system is fine excpet for the graphics card!
with it being built in theres no way of upgrading it i take it ? unless changing the mother board which is oviously pointless ?
I expect that the mother board will have a PCI-E slot but it will just not be in use. But I can't be absolutely sure since it doesn't tell you the make/model of the board.
go to www.pcoption.co.uk
Cracking pc's at very low prices. they use quality components, you get a 5 year warranty and you can speak to them on the phone at any point and will guid you through a lot of things.
You would not be disapointed with a pc from them
eg
Performance Base Units.
AMD Dual Core Socket 940 AM2 5000
Standard Case ,
Msi NX8500GT-TD512EH
400GB Sata 2 Hard Drive
2048 DDR 2 667 MHz
Vista Premium & Disc
Sony 18 X DVD Dual Layer Writer
M2N-E Motherboard
52-in-1 card reader
£410
thanks for the heads up
had a look but dont understand enough to confidently buy a particular one,
does anyone know of a web site that can tell me what each part does, ?
ie ram does ? processor does ?
god i must be thick lol
give the people at PC option a call, tell them you budget, what you want your PC to do and they will tell you exactly what you need without ripping you off.
For what you want, the above machine is more than capable enough
eg
Standard Case ,
2048 DDR 2 667 MHz
M2N-E Motherboard
52-in-1 card reader
£410
which one is that cant match it on the site ?
wow i never been so confused theres so much stuff i didnt/dont know about computers,
someone pick a computer for me lol
