Electrical warning light is lit up, and fuel pump isnt priming, I recently started another thread but I have since narrowed down the fault to being with this.
- Tested relays by cleaning the terminals and running across battery all seven clicked over.
- Taken rear seats out cannot hear or feel anything from the pump.
- Used on board computers' built in diagnostics and I am getting t--- which indicates fuel injection problem for a minimum of four seconds.
- Checked all the fuses under fuse box in the bonnet and all the interior ones I could think may affect engine running.
Could this be down to Crank/TDC sensor? or Coil pack? Or pump?
What should I try doing now? The car will crank over religously but just won't fire?
Cheers.
Cheers.
