Warning Light Problems
Car  clio 182
Hi,
I have had a search and can't find this direct problem. I hadn't used my car over the christmas period due to the snow and personal reasons. It's been almost a month since I used it.
I came to use it today and at first it wouldn't move, I think the breaks must have froze, afew revs and I was free, however, plagued with warning lights.
Ignition on, everything seems fine.
Start the car the centre console clock goes off, the STOP/battery light flickers on and off. There is no fan/aircon.
When I give afew revs and go to pull away the clock flashes on and off, the ABS/ STOP/ SERV/ ESP lights come on. Also the lights and indicators don't work, although they do when I have stopped or have the clutch in,break on.
There is the odd clicking from the fuse box. When I drove around the seat belt light was on and the handbrake light but after a few minutes the seatbelt light went off and the airbag and I believe its the engine light on the right side, not the centre on came on.
Anyone have any ideas where to start?
And today alarm wouldn't stop going off and I couldn't open the door. Opened by the passanger side manually, tapped the fuse box and opened the bonnet, seemed to have stopped the alarm aaahhh.
I called the AA out as I couldn't get in it. The battery was obviously flat. He disconnected and gave that a charge. All was working well, no warning lights etc. He did say the battery was tired and I needed a new one but it would be ok if used regular.
Last night at 1am the alarm was off again for 5 mins or so. Checked this morning and the battery is flat again. I am hoping it's just a battery that needs replacing and nothing is draining it.
