washer jets help!
  PB Clio 172
as above is there anything I can do to avoid buying new ones from renault, the washer jets on the headlights
I am total crap at diy jobs
1 works but the other just sprays at the car infront(which is kinda funny) but its no good for the MOT business which is about now
Something I can put in it maybe ?
please help!
  MG ZR 1.8
Maybe use a pin in the tiny holes that it comes out of to Change the direction ?
It's prob not that simple though ;)
  Titanium 182
If it's the headlight washers, have a look at which direction the little 'slot' on the jet is facing. By the sounds of it, it's not leaking but directing forward too much. Get something small and wiggle it back around to face the headlight - a coin should do it!
  PB Clio 172
i havent got the bit on the top its missing
can i put something else in there to make it go forwards
it leaks a bit too
  Golf GT & A4 Avant
so you don't have the actual plastic washer jet that sticks out the bumper? I'm not quite suer what you mean. renault or 2nd hand I'd imagine for replacements
  PB Clio 172
yes i have that but as i said the water from the right side squirts forwards instead of at my headlight!
  Golf GT & A4 Avant
there is only a slot on one side for the water to come out which should be facing the headlight. post a pic up as I can't work out whats wrong
  Seat Ibiza
Im guessing your missing the ball that sits inside the jet housing that sticks out the bumper?
  FiestaST(ex 172 Cup)
Compare the good side to the bad to see what's missing and find something to put in it. Not sure what we can do without actually seeing the thing.
