water leak
RB182CUP-FF
Car  2118's RB 182 CUP
hi i got a leak in my car all the passenger foot well is soakd has any1 got the same proplem or know where the water mite be comeing from?? cheers
lee :(
Depending if its engine coolant or rain.
Rain then drain plugs under the scuttle panel or door seals.
If its engine coolant heater matrix
I see more sunroofs and aerials leak then scuttle panel drain holes.
We have had them in though when the drain holes are so bad (there's three) that the water is building up and coming in where the heater blower is
i had a similar leak, it was coming from the rear wash pipe.
remove the wipers (give them a GOOD tug) and remove the scuttle panel, then the wiper motor and finally the washer bottle, (seriously only 10 mins once the wipers off)
under all this is the pipe feeding the rear wash, on mine the grommet had come lose, good squirt of sealant and job done.
