I've been losing a lot of coolant from my 182 recently and from looking around I'm pretty sure its leaking from the water pump area. I went to my local Renault dealer and they said to replace the water pump they also need to change to cambelt (already changed last year). However from a search on here I've seen people say that you only need to change the aux belt when changing the water pump on the 1*2.
Can anyone confirm this is correct or do I indeed need the cambelt changed as well?
