what about your HU ? does that work with your lights off.
somehow somewhere you must have the lighting wire that goes to your headunit in the wrong place. does you HU loose its memory when turn the car off and come back later ? does your HU stay on even after you have turned of the acc position on on the ignition ?
Is it not quite frequently the other way round? With some headunits the remote turn-on/accessories/electric aerial output for connecting to your remote lead for the amp is actually orange or brown? I know for a fact that on my last two head units (aiwa and JVC) the correct output on the headunit wasnt coded blue! The lighting lead would usually be an input connection to the headunit, feeding it a signal so it knows when the lights are on. This wouldnt turn on the amp when the lights are on I wouldnt have thought.
