What Alloys??
Car  1999 Clio Alize
I have just taken ownership of a completely standard mk2 ph1 clio. I am now considering getting myself a set of alloys but i'm on a tight budget and am completely new to this sort of thing.
Firstly, what sizes should i be looking for to go on a clio?
Secondly, where can i get cheap alloys & tyre packages?
google is your friend.......
seen as your new to this ill point you in the right direction, you want to be looking at alloys that are 4x100 pcd and offset of between 35 and 40 with a center bore of 60.1 or above. if you go for new aftermarket wheels from a shop they should give you bolts and spigot rings if you need them.
oh and get 15 or 16" wheels max, anything obove this you will end up getting abuse on here....
if your on a budget get on ebay or in the forsales section on here and have a look for some 2nd hand oz f1s off a ph1 rs or some speedline turbines off a mk1, could even look for some mk2 ph2 dynamique alloys if you like the oe look.
