i keep seeing "acoustic valve" popping up in forums,could somebody explain what it is,thanks.
adamg1 clio 172 Jun 15, 2007 #1 i keep seeing "acoustic valve" popping up in forums,could somebody explain what it is,thanks.
Sib Clio 172 (Silver) Jun 15, 2007 #2 Its a valve to make the air induction noises meet eu specifications due to plastic piping being used. It should only really affect the noise levels of the car slightly and performance even less so. If you want to fit a larger bore air feed you need to remove this.
C CHRISK172+ Vectra 1.9 CDTi SRi 150 Jun 15, 2007 #4 You can also find info and pics here. http://cliotrophy.co.uk/forum/viewtopic.php?t=1592&highlight=acoustic+valve
C CHRISK172+ Vectra 1.9 CDTi SRi 150 Jun 15, 2007 #6 adamg1 said: oh cool,just on the ph2's ? Click to expand... Not sure about ph's 1
Da Less Jun 15, 2007 #8 It's down behind the near side wheel, under the headlight area. It's for EU directive on noise pollution. Removing it should give you a little more induction noise but could reduce low-down torque.
