your 16V has hydraulic tappets, switching to solid tappets will mean the use of shims to set the clearances during the rebuild, and its an annoying time consuming process.........
Sorry forgot, hydraulic tappets are simply a piston in cylinder. They get pumped up with oil at all times. As the cam depresses on the follower the piston moves up untill the bleed hole is covered and no more oil is squeesed out, thus oil is incompressable and force is put into the valve, until this bleed hole is coved, no force is put on teh valve tip.
