WHAT CHIP AND WHERE TO GET IT FROM
  Clio sport 182
going to keep it short and sweet, I have a 182 clio with decat and bmc cda air filter fitted. What chip would you recommend for the car. The chip must ideally map out the rear o2 sensor.
thanks in advance
R3k1355
Why do you need it to specifically map out the rear sensor?? It rarely gives issues.
Most people use the RS Tuner box, but you don't actually get any real power gains just makes it abit run a touch better.
  Clio sport 182
If the rear o2 sensor doesn’t see the correct readings all the times the fuel Trimm’s will be unsteady and can in turn cause running issues
  monaco 172
Nah, does nothing, just needs to be plugged in.
Mines been hanging from then abs sensor wiring for years as I ruined the threads getting it out of my old cat
It only needs mapping out if your planning on unplugging it completely.
  Renaultsport Clio
I might be interested in chipping mine. Does it make a big difference to acceleration and does it make the insurance skyrocket?
  172
No and yes (if you're young).
No and no (if you're old).
The maps from RS Tuners/Fastchip raise the idle slightly, raise the limiter to 7800 RPM and smooth out the torque delivery a little. The smoother torque is noticeable around 5k RPM but it doesn't feel any faster. But then you wouldn't actually expect to feel 1, 2, 3% more BHP anyway.
497adam
  clio 172 phase 2
thanks in advance
Where are you ?
